Changing Genre in DTC
Posted by: hungryhalibut on 14 July 2013
Can anyone advise how one can do this? I've just ripped a 4 cd set, and two show as 'classical' and the others as 'misc'. Very annoying!
Posted on: 14 July 2013 by m0omo0
Have a look here:
https://forums.naimaudio.com/to...-addedit-music-genre
HTH
Maurice
Posted on: 14 July 2013 by hungryhalibut
Thanks. The thread explained a bit more about nServe. I've been able to change the genre via that, really easily. I've got all the album art too, though nStream doesn't seem to be picking it up, which is odd.
It's now sorted. I found a post from last year, which suggested deleting nStream and reloading it. Someone suggested that was not necessary, and that all you had to do was clear the upnp cache, but that didn't work in my case. A reload fixed it though.
Posted on: 14 July 2013 by Prubast
just  be careful deleting NStream if you have any playlists as they will be gone if you do.
