streaming flac using amarra hifi 2.4.2 + itunes..
Posted by: Antonio1 on 15 July 2013
is it possible flac streaming on macbook pro and will solve the issue unitiqute 24/96 unusable o stream over a mac  ?
Posted on: 15 July 2013 by DHT
Amarra will play FLAC files.
H
Posted on: 15 July 2013 by Antonio1
hi thanks
but unfortunately the cheaper amarra hifi I have won't be able to play flac :-(
macbook pro seems affected by jitter massively (unlike macmini I've read)to justify a good optical cable such as wireworld optical one's to sort the issue ?
what would you suggest?eyconnect?
