Adventures in asset UPnP?
Posted by: Tog on 19 January 2011
Actually I like V3 a lot - It's quick , runs most codecs and handles Cover Art at reasonable resolutions - one of the few failings of miniDLNA on Vortexbox.
Running a new mini TogServe on a Sony Vaio netbook hardwired to router.
I'm struggling to find fault at the moment - flacs maybe sound a bit brittle on the Uniti and Asset lacks the Vortexbox simplicity. I'm loathe to go down the WHS route but I'm a bit tempted. Can it be set up to autorip? Does it have issues I haven't spotted ... ?
Tog
A nice feature I find is that it can be configured to find music by various different means including 'Folders and Filenames' which I find ideal since I file my music in subfolders under main 'genre' folders. Obviously it does by 'Album' and by 'Artist' easily aswell.
I paid for the registered version and now have it installed on a couple of netbook PCs aswell. I can plug in a USB drive, use Asset locally on the netbook(s) and stream music from them over the network as I choose. I use 'PlugPlayer' as the control point which immeadiately sees which 'Asset' locations are live and allows me to switch locations to call music from whichever i wish.
dBPoweramp is available in a version called 'RipNASEssentials' which i have running in WHS on the NAS. This allows me to rip CDs complete with metadata and album art direct into the NAS using a USB attached DVD-RW drive.
'Spoon' as he calls himself is also developing 'Asset Control' which currently runs on windows PC's but will eventually be made available for i-devices. I use it from time to time on a netbook. A very nice interface with very quick search and list facilities.
regards
Geoff
Tog
Hi Geoff
Thanks for that information. I put Asset on my main PC streaming to a Qute to try, and I must say it worked like a dream, but I don’t want to have a PC on to listen to music.
Problem is my ReadyNAS occasionally fails to send an Album or Track to the Qute, which when it happens is very annoying. Also the NAS absolutely refuses to send ANY WAV file to the Qute; they just aren’t visible to it. This is using the built in DLNA server on the NAS.
No such problems were encountered using Asset, every file was visible and played during the short period I used it.
I have been trying to audition a Serve but have not yet succeeded, I have wondered about a WHS box with Asset as a possible alternative. Seems promising from your findings.
Peter
WHS has its own version of RAID which is called 'Fileduplication' which works across the 4 disk bays in the Acer. which comes with an Acer customized version of WHS that has a couple of little routines in it that aren't std which are quite nice.It also includes an i-tunes server for those that want it.
Works well for me
regards
Geoff
IMO Asset in combination with RipNas products is really good alternative to Serve, I'm waiting for the Asset control to get out of its beta to see how stable it will be. Moreover, they are Vienna based company so another advantage for me :-)
Tog
![]() | okli Senior Member | Today at 08.50 |
Hi Okli……..Yes, I was warned to check for that by Phil I think it was when I said that I didn’t think the files via the PC and Asset sounded as good as when played from the NAS. Another problem with my NAS DLNA server is that it will not send any WAV file to the Qute. If I mix WAV & flac files in the same folder it only shows the flac files on the Qute screen. When I put WAV files in their own folder it doesn’t even show the folder on the screen; it really is very strange. Via Asset everything was visible and played.
So Illiustrate are a Vienna based company are they, I don’t know why I assumed they were German. I think most would agree they are very good at what they do.
Peter
P.S. We all age at an alarming rate on here now, 3 Days ago I was still only a Member, now I’m on my last legs, scary.
Tog
In combination with the Control and Renderer makes a very powerful trio.
Encouraged me to spend a couple of hours grabbing jpgs of the album covers!
It also streams all my flac files as MP3 to my Sony BluRay, its DLNA client won't hand anything else.
M
At last I found how to quote - Hi Peter, the company behind RipNas is mCubed or more popular as HFX - I was referring to them. I don't know what are their connections with illustrate, but the combination is really good, as you said.
or UnitiServe (very expensive)?
I think it depends on the requirements - the difference is do you need all-in-one ripper + streamer or only the streamer. And the storage extension boxes look quite nice as well.
Vortexbox is great but once you have allowed for a proper server to put it on - the difference between that and RipNAS is not a lot.
I haven't come across Control and Renderer ... what are they?
Tog
Don't you think Naim should sell their ripper and server as standalone pc applications? Would bring an awful lot of people into the Naim fold.
Please don't start this discussion again ;-)
I'll be quite happy if Naim co-operates with Asset and their make a Naim-plugin for Naim devices... but, this could hurt UnitiServe market...
The biggest problem I have found with all other UPnP Server software is the lack of feedback information, preferences and control features. eg. Eyeconnect just tells me it is running, miniDLNA tells me the folders it is connected to, Songbook $£! all since it usually crashes, XMBC - Widescreen bonanza of menus non of which make much logical sense!!, and Allegro - well I know its there but not much else.
Asset is the first one that actually feels like it's a program that someone cares about - and it works first time with great album art.
I do think it would partner well with Naim (and save them a packet) - my dealer doesn't think the Serve sells that well in any case.
Tog
As Spoon says on the Illustrate web site: ( once there search 'Renaissance')
- Built in UPnP Renderer: Renaissance enables your PC as a UPnP playback device, it can stream audio from a NAS / web for a distributed system where multiple playback devices can be scattered around the home and playback from a single audio store, controlled by hand-held remotes, such as the iPod touch. (Renaissance appears as a UPnP Renderer, with Linn DS extensions)
- Gapless playback: sample perfect decoding of mp3, Ogg and without saying any lossless format.
- Bit perfect playback using WASAPI to bypass Windows mixer.
It also works with crossover MAC I believe.I use it with a Win 7 netbook which has SPDIF & analog audio out when I fancy some music in the bedroom system
regards
Geoff
Okli
Ah, I see. Thanks for clearing that up.
I do need to ask you. How are you doing it?
Getting younger I mean. Now I know you were a Very Senior Member yesterday; now you are a Senior Member again. Whatever you are doing I could do with some of it, I get worried ever time I press the post button what I may be next.
Peter
The Vortexbox project is run by one man not a corporation - which is why I marvel every time I press update on my iPad and Vortexbox installs a whole host of improvements. This is on top of the regular major point releases that seem to appear every three months or so.
Good news is that after requests made over on the Linn forums the issue has been fixed. Cover art resize can now be set to a maximum figure. That is what I call customer service and a strength of the Open Source model.
Sorry guys - I will shut up now.
Tog
Have you had a look at Linn Kinsky?
M
Nothing ....
Tog
