Admin - Why can't I reply to any threads?
Posted by: Voltaire on 23 January 2011
Admin - For some reason I cannot reply to any threads in any room?
Am I suspended?
Advice appreciated.
Gordon..................................................
George - I am not able to reply. Nor can I put spaces between my sentences! WTF!................I can't change watch topic from yes to no............I've been gremlin'd!............I am using firefox on windows 7.
Posted on: 23 January 2011 by George Fredrik
Dear Gordon,
Still got two CD albums of yours - carefully looked after from Hereford days five years ago now.
I don't know where you are based now, but if it were convenient, you would be most welcome to visit, chew the cud, and listen to my much more humble set, and have them back if you like the idea!
Best wishes in any case, from George
Location is still in Worcester: Saint Johns. Email in profile.
Posted on: 23 January 2011 by Geoff P
Voltaire
Are you by any chance using FireFox? I have similar problems to those described by you in FireFox. Changing to IE 8 which I also have seems to put things right.....Not that that pleases me since I don't want to use IE.
Geoff
Posted on: 23 January 2011 by kuma
Geoff,
It works on FireFox if you are using a mac.
Posted on: 23 January 2011 by MilesSmiles
Had the same issue yesterday from my office PC, pressing toggle under the reply box finally solved the issue but messed all the formatting up.
Posted on: 23 January 2011 by Voltaire
Ah, yes switching to IE8 has solved the problem but not an option for me I'm afraid as I use a great many plug ins attatched to Firefox.
Hopefully it's a temp hiccup.
Posted on: 24 January 2011 by Richard Dane
I use Firefox and haven't yet had any issues. Having said that I have terrible problems that seem to come and go at random on a few other forums I check into every now and then. After a great deal of testing and an exhaustive process of elimination, it seems to be an issue whenever I use mobile broadband. Unfortunately I'm forced to use Mobile Broadband at home due to limitations in the BT infrastructure.
