Controlling Loudness witn n-Stream apps
Posted by: SamSam on 31 January 2011
Hi All,
I wonder if it would be technically possible to have a loudness capability on n-stream apps working together with a the naimuniti. I assume not but appreciate your input
Posted on: 31 January 2011 by TJ
Hi SamSam,
NaimUniti doesn't have loudness control circuitry which is why this setting is not available on n-Stream when connected to a NaimUniti. The UnitiQute does have a Loudness control so this setting is available when n-Stream is connected to a UnitiQute.
Tom
Naim R&D
Posted on: 31 January 2011 by SamSam
Thanks TJ
Can we imagine that such loudness control woud be workable with the uniti assuming an update in the firmware which would support it. Technically this could be a loudness control on the digital music format before it is converted and amplified to analog output
regards. Sam
Posted on: 01 February 2011 by TJ
Hi Sam,
There are no plans at the moment to add this feature to Uniti.
Tom
