After buying a UnitiQute plus Apple ipod touch I ripped a bunch of CDs to a WD NAS using db poweramp, no problems. Then downloaded n-Stream in order to control the Qute from the ipod, again seemed to work fine. However I see no artwork on the ipod. I would appreciate any suggestions to help me solve this problem.
Stan
Posted on: 06 February 2011 by David
Stan,
it is most likely to be to the UpnP server software running on your NAS.
Depending on the software you need to have the album art stored as folder.jpg or cover.jpg. Dbpoweramp stores it as folder.jpg by default.
it took me a while to figure this out with my ReadyNAS, but once I changed all the file names to cover.jpg it all worked perfectly.
Posted on: 07 February 2011 by Stann
Thanks for the info Dave. I have the artwork again since I did a second restore on the ipod.
Stan
