Unitiserve & TeddyDac
Posted by: Louis-Andre on 25 July 2013
the sound coming out of my Macbookpro(wireless) / SBT/TeddyDac is IMHO almost on par with my CDS3 set up... so close in fact it took me quite a few tests to assess for sure.
So not sure it makes sense to keep the CDS3... also the Macbookpro belings to my wife so I would need another replaczment source.
As anyone tried a Unitiserve  with a TeddyDac?  i think it should be even better than via the Macbookpro, but have not tried
Louis
Posted on: 30 July 2013 by andrew0810
Can“t tell you anything about the T-Dac. I use my UServe with the NaimDac and XPS2. But I couldn`t say that the Userve was on par with my CDX2 (with NaimDac and XPS2). The Userve was more muffled than the CDX2, there was less detail and less treble.
I'm a liite bit surprised, that Naim - that takes so much care about power supply-  uses such a cheap PSU for the UServe and doesn't offer an upgrade...
Posted on: 30 July 2013 by pcstockton
Dooooode.  A Naim DAC with XPS is a must in that system.  Forget the TeddyDAC.  Ebay that thing.
-patrick
Posted on: 07 August 2013 by Peter Dinh
-patrick
Just bought the TeddyDac and agreed with the OP that the TeddyDac sounds fanstastic. I am quite surprised that pcstockton made a sweeping comment? Just wonder if you have heard this little gem.
Posted on: 08 August 2013 by hungryhalibut
I heard one of these, fed by a Roksan CD player, and it was very good indeed. Just because it is not made in Salisbury does not make it rubbish.
Posted on: 08 August 2013 by Louis-Andre
judging by his comment, i bet Patrick did not hear it. The TeddyDac is the best bang for the buck that I made in a long time, and to my ears betters the NaimDac by a bug margin
Posted on: 08 August 2013 by GraemeH
I thought the bear word was filtered out? G
Posted on: 09 August 2013 by james n
Best + cap tends to arouse concern. Good products though.
Posted on: 09 August 2013 by pcstockton
I have not heard it.  My suggestion just seemed logical from a system synergy perspective.
Bear - bloody predicitve iPhone.
Posted on: 09 August 2013 by Peter Dinh
lol, i have so many problems of the iphone trying to be too smart in typing prediction, especially with my native language that is Vietnamese.
Posted on: 09 August 2013 by BigH47
Turn the PT off then, it's rubbish anyway.
I sometimes need it, but i have to be careful with PT if the message I send is deemed important.
I understand Peter, that you might find it helpful, but it is a bit flakey at times.
Posted on: 16 September 2013 by Sloop John B
Just listening to a squeezebox touch into the name DAC  and it is a great combination.
I'm sure your TDAC is giving you similar results.
What are you connecting the squeezebox to the DAC with?
Posted on: 17 November 2013 by Louis-Andre
Hi Sloop John B,
Sorry for the late reply. i use a Chord Signature.
I am listening less and less to my CDS3, and much more to the SBT/TeddyDac... The difference in SQ is so small I cannot justify keeping my CDS3 any longer...
