High End iPhone Cable
Posted by: sailorck on 26 July 2013
Do you guys have any advice for an iPhone to nDAC cable of a decent quality? Should be based on lightning (iPhone 5) connector.
Posted on: 26 July 2013 by Bart
I would use the $19 cable from Apple.  I know of no deficiencies.
Do you hear something using that cable that you're trying to remedy?
Posted on: 26 July 2013 by Phage
Hello, I'll hijack this thread since the subject is close. What happens if iphone rings while attached to ndac and Spotify is playing?
Posted on: 27 July 2013 by sailorck
No, I was just wondering if other cables could be better.
Posted on: 27 July 2013 by pt109
Not quite sure about iPhone5, but I had a convincing demo with a Audioquest Forest USB for iPod cable. Difference was surprising against the stock wire.
Posted on: 27 July 2013 by GraemeH
I'm confused - unless you are streaming at least CD quality files (a rarity as far as I can tell) isn't the quality of that cable marginal in the scheme of things? G
Posted on: 30 July 2013 by Phage
Originally Posted by Adam Meredith:
Everyone in the room will look at you with disapproval and mime "Ssssssh".
: D one hardly can prevent that, now can't they?
I actually wonder that does that turn my system to a phone speaker or just "unplug" the iphone to operate as it is - a phone?
