All Digital Inputs on AV2 are dead :-O
Posted by: GreenAlex on 01 August 2013
I had my entire System (DVD5/AV2/NAPv175/NAP200) powered down because I was away for a few days and wanted it all to be nice and safe.
Came home and turned it all back on and wanted to watch some TV (sat receiver via toslink) but the signal kept dropping and then plops and weird noises came from my speakers :-O
Reset the DVD5 and AV2 but still, both on Toslink and Coax the signal locks, then after a few seconds no more sound and then some plops and weird noises :-(
The VIP inputs (analogue CD from DVD5) works with no issues at all. Both in Direct mode and in NEO:6 etc.
Anybody ever had this? Any ideas? "Newest" firmwares on everything. AV2 has been working without an issue and was turned on 24/7/365 and now i turn it off for a week and it breaks down?
Please someone tell me this can be fixed locally by a reset or some kind of adjustment?
Pretty please :-)
Posted on: 02 August 2013 by Richard Dane
Hmmm... That doesn't sound good. Hopefully just a scrambled DSP but maybe chipset. Did you unplug everything, including aerial etc from the tv? Probably worthwhile giving naim a call but be quick because shutdown starts end of today...
Failing that, once I get back home at the weekend I'll try to dig out my old AV2 troubleshooting documents and see if there's anything there to help.
Posted on: 02 August 2013 by blythe
I'm sorry to say that it sounds very much like the same thing that happened to mine a few years ago after some lightning and thunder in the area......
Posted on: 02 August 2013 by GreenAlex
@Richard:
Would a "scrambled DSP" be fixable locally then or would it just be a "smaller" repair compared to the other possible sources?
I did not unplug anything yet. I can do so if you think it helps but I figured since analogue works fine and optical connections do not trasmitt electrical noise (sat receiver is connected optically and only DVD5 via toslink), I didn't think there would be much point.
@blythe:
No need to build up suspence ^^
What was wrong with yours in the end and how where you or was Naim able to fix it? Or was it an expensive paperweight afterwards?
Posted on: 03 August 2013 by Richard Dane
If you still had stuff plugged in to the AV2 - particularly a TV or sat receiver box and these weren't unplugged from mains and/or aerial then any spike or somesuch from the recent storms may have zapped the chipset.  A scrambled DSP can usually be fixed just by a hard power down and power up.
Posted on: 03 August 2013 by GreenAlex
We didn't have any storms here. No power outs. No spikes. So it really just was from turning the system off and on again.
Also the entire Naim system is electrically isolated from any and all other devices.
Meaning, all connections from anything other than the DVD5 is toslink. So basically an isolated system. Even a dedicated spur
Is a hard power down shutting it off without putting it into standby? Or a special power down routine?
And, most importantly: Thank you!
OK thanks.  That does rather rule out a number of possibilities. If a hard power down and power up doesn't clear the problem then try a factory default reset;
To restore the factory defaults, go into the setup page (Input setup mode, press & hold the Input button on the front panel, speaker setup mode, press & hold the mute button) then in each mode press & hold the handset display button. (display flashes once to confirm)
If that doesn't work then try a power down and power up again.  Beyond that, it's then something you should contact your dealer or Naim about.
I didn't do the individual reset but will try that tonight.
I did the global reset via the remote.
Not looking good, is it?
But will give it a shot
I thought I had gotten lucky, but I didn't
Turned it on after two days of power down and reset each page.
Tried a DVD right away and worked. Tried another. Worked.
Switched to optical abd it worked. Switched channels (sat receiver running enigma2 [dreambox]) and everytime you switch channels it cuts the optical output. So the AV2 has to relock onto the signal. Never caused any problems. Now it does.
Seems like whatever i wrong with the AV2 is triggered somewhere on signal loss or when it tries to reconnect or reinitialise or whatever it does.
Left it running now while I am away to see if it loses the signal and starts plopping again even when the signal is constanly there.
Will reset my satellite receiver tonight as well. Just to make sure.
Is the signal processing unit (DSP) soldered or is it the unit that is swapped when chsnging the firmware? I think I might still have the old firmware chip somewhere from when the software wss updated.
Any point in trying that or are the two not connected?
No way - don't touch it.  You'll likely cause electrostatic damage to the chips.  It won't show straight away but the breakdown will happen gradually until one day in the future (maybe very near future) they fail.
Performed with the necessary grounding precautions (not sure what it is called in english) when we replaced the chip last time. Could do it again, if that is the chip in question. Of course system and technician would be "grounded" ^^
But as I said, only as a last resort and only if that is actually the chip affected. Don't worry, I love my AV2 very much and I will do all I can to save its precious life :-)
Best take Naim's advice here.  Unfortunately now on break though, so perhaps talk to your dealer.
Will wait for Naim to return fron their summer break then :-)
It's been years since my dealer last had an AV2 so all he could do is send it back anyway (not complaining, just logical that this kind of problem can only be sorted with Naim HQ really).
Maybe turning the volume to 99 and leaving the house for a few hourd will set it straight again ^^
Posted on: 03 August 2013 by karyboue
@GreenAlex
I hope you can solve your problem.
@Richard Dane
What is what you call "scrambled DSP" ?
I use my AV2 everyday for hours but may be once every 10 days, it sticks with "No Sig" flashing on every digital input.
Fortunately, it can be solved with hard power down and power up procedure.
Is this regular failure the beginning of the end for my AV2 or a usual bug that I shouldn't worry about ?
Posted on: 04 August 2013 by Richard Dane
Karyboue,
no, I think this is not something to worry too much about.  The AV2 was fairly sensitive to any mains anomolies, whether directly or via anything with a floating mains attached to it through signal interconnects.  In my old house I had pretty variable mains and sometimes this would happen quite regularly - I'd come home and find either no signal or lost settings.  A hard switch off and on would clear it and it would then be fine.
Posted on: 04 August 2013 by blythe
Sorry for my late response - Naim did indeed fix my AV2 which is still serving me very well
Posted on: 04 August 2013 by karyboue
Originally Posted by Richard Dane:
Karyboue,
Thanks.
Posted on: 04 August 2013 by GreenAlex
Yeah, mine sometimes got stuck on "no sig". Power down and back up and it was sorted.
I spent 4 hours until 2am trying to solve it somehow.
In the end it has become aparent, that the av2 does have something wrong with it. Ruled out everything else.
Managed to screw up my sat receiver doing so, so will need to reinstall the firmware on that tonight^^
But I must admitt, that if i could remember where i put that firmware chip I might have swapped it last night just to check if it fixes things. Will look for it again. I know i did not throw it away.
Sorry Richard, I promise I will take all the needed precautions! But right now I have a very expensive, although pretty looking, paperweight
If only I didn't have real work to do now... -.-
@blythe: I figured Naim was able to fix it. I was wondering what they had to fix?
Can't see anything obvious wrong with it. No fried chips. Where is the DSP in question located? Is it one of the PLCCs?
Posted on: 04 August 2013 by DavidDever
I would definitely leave it be until your retailer can coordinate further diagnostics with the factory / distributor.  There really are no user-serviceable parts inside and, as Richard indicated above, the surround processor board module is rather susceptible to ESD damage.
Alex, as you have it open and you say you have all the correct ESD precautions in place (strap, ground mat, clothing, shoes) then you might want to carefully lift the PIC chip with a PIC removal tool and then re-seat it.  Maybe just a poor contact.  Worth a go.  If you don't have the full precautions then don't touch anything - it'll inevitably result in chip breakdown somewhere on the board, if that's not already the cause of the problem.  This board is very fragile and prone to ESD if not handled properly - just a wrist strap won't cut it.
All the precautions are in place.
Removed the new PIC and put it back in. Nice and firm. Will test now.
May I ask what those other two chips are? The one with the F and the one that says Naim 6.58?
Edit: Nope, didn't solve it. Either needs a new PIC or needs a new whatever might be the cause
What I find curious is, that although it is on digital inputs, it sounds like static. Like white noise.
It seems to happen when the AV2 loses the signal and has to start decoding/processing again.
It does not seem to happen while the stream is constant. Only after the signal is lost (e.g. switching channels) and the AV2 locks on again.
Probably someone at Naim knows exaaactly what the issue is and why this is happening, whilst I just feel like kicking that gorgeous black box -.-
Posted on: 06 August 2013 by tonym
Hi Alex,
Sorry, can't help you on this one but it's good to see you back on here again!
Hope you get this sorted quickly.
Best wishes,
Tony.
Posted on: 09 August 2013 by rackkit
Sorry to hear about your AV2 Alex. Just back from a work trip in the States. I left at the same time we were having the thunder storms so unplugged the entire system before leaving. I even went as far as removing the optical cable from the Virgin box to the AV2. Turned it all back on and everything seems to be fine. Hope you can get yours sorted out.
Rack.
Posted on: 12 August 2013 by GreenAlex
Thanks guys :-)
I will contact Naim mid-week to give them some time to return from their short summer break before bothering them with my broken av2 :-D
