Radio Paradise - skipping!
Posted by: Timbo on 02 August 2013
Just started listening to this station! Is it my imagination or does the music keep skipping? Sounds like a bad stylus on a non setup turntable. The buffer is full and no other stations seem to do this.
Is it me or them?
Tim
Timbo missed your post and started another thread.
Which RP version are you listening to? I'm having trouble with 320 Kbs version, off website or 192 seem OK.
Have you just done the iTunes update to 11-0-04(4) ?
Hi all:
Am listening to RP (320) through my Unitiserve SSD still keeps skipping, will try another station and report.
Tim
Have been listening to Classic and Jazz at 128, no problems so far. Seems little point in having a station at 320 if it keeps skipping :-(
Tim
Yes, also experienced minor skips in the RP 320 stream on my unitiQute.
i first thought it might be my Internet provider (talk talk) but now that others are having same issue, it's most likely a problem on the RP side.
I just tried Paradise at 320 and it plays perfectly. (I'd played Paradise for around 30 minutes before posting this)
My internet connection is typically around 6mbps and I have a wireless connection to my HDX.
