Connection
Posted by: sf on 04 August 2013
Can anyone help me
with Remote control
hdx to nd5xs which cabel and where to plug
Nac282 to nd5xs which cabel and where to plug
If you go to the Naim main website you will find PDF versions of the user manual for all products. These include clear diagrams of the back plates and all the connection permutations. The pre amp and power amp user guides are the same for all models, being one big book covering them all.
The last time someone was here from the dealer installing something for a try out, he used an iPad over our WiFi to access the website and double check his work in situ. Very handy.
Thank you.
But... There is no Remote connection ón the back side of the NAC 282, and no pdf I Can find to help me
Is this by any chance the 4mm to mini jack plug which allows control of the pre amp volume and source selection through nStream? The HDX won't be involved in this process, it's just a link between the ND5 and the 282.
RC5 in (phono) on the 282 and remore out (jack) on the ND5. Plus enabling on the ND5.
If I'm understanding your question correctly.
TanksTanks![]()
Sounds like you got a result. Glad to hear it.
