Howard's iMac problem #?
Posted by: BigH47 on 13 August 2013
OK the problem is whilst listening to music from NAS - iTunes-iMac - DAC to system, I can still hear notifications from Facebook.
I have been into System preferences and in Personal, stopped all sound notifications Chrome , Mail etc.
Is there a way of selecting NO SOUND for alerts in SP Hardware - Sounds? I can change sounds but not select for none.
I can't see any way of selecting no sound in FaceBook, not that that is surprising as it's such a POC software.
Any ideas ?
TIA
Howard
Posted on: 14 August 2013 by BigH47
Finally I think I have found the settings I wanted, in true FB tradition not where you would think.
Posted on: 14 August 2013 by Derek Wright
Well share out this bit of information......Please
Posted on: 14 August 2013 by Deeg1234
Howard,
Under sp sounds..sound effects where you select the sound set, there should be an option to disable/enable interface audio feed back and to set alert volume. Also, if Facebook is using Notification Centre, there is also an option in SP Notifications to disable audible alerts.
which version of osX are you running and does your signon have admin rights?
Deeg
Derek :-
https://www.facebook.com/help/302202129901479
Posted on: 15 August 2013 by Derek Wright
Many thanks
Posted on: 16 August 2013 by winkyincanada
Does Facebook try to bong you even if your browser is shut down? What if your browser is open but not on Facebook? (A noxious piece of software, for sure)
