To all those having issues with Internet Radio
Posted by: J Saville on 13 August 2013
As part of the 1.7a update to all Naim Server products, the feature for streaming internet radio over UPnP has been added. This means that the Serve does the buffering for Internet Radio, much more stable.
This feature must be activated through DTC, Select the Tools tab, Settings & Functions, System Settings. Select the 'Naim UPnP Server' tab, find internet radio, and set it to True.
Another reason to buy a serve.
Enjoy!
J Saville
Intriguing. How did you come by this information JS?
Generally Internet Radio is fine for me, but every now and then it has a wobble and struggles with the higher bit stream stations, presumably because of slower broadband speeds or network traffic.
Anyway, Ive changed the setting in DTC as you describe.
Im curious to see what effect it has, if any. (must remember that Ive changed it though in case I need to change it back
(Uniti1 / Unitiserve / Neat Motive 2's)
I have my sources...
I have done some testing and was able to comfortably stream 2 different 320k streams on 2 different streamers (NDX, Qute 2) with no buffer dropouts on an incoming connection speed at less that 10mb/s! This is a huge improvement as I would struggle to play even 192k streams in some cases using streamer internet radio. Well done Naim, a big step in the right direction.
It's the PC Client that allows the user to make the most changes to set up, if I'm not mistaken.
There is also the Flash version web type interface through Internet explorer, but DTC gives more functionality.
And it is for Naim hard disk players and servers.
And don't forget n-Serve for OS X, which is essentially the DTC for Macs. It's available on the iTunes (App) store.
Enjoy!
J Saville
Can this be achieved using n-Serve on a Mac? I have just gone into UPnP settings - Internet Radio - Allowable device views, then changed it from false to true. Or, is that nothing to do with it?![]()
That should do the trick (I don't have a MAC to try it)
If set then you should see it appear under UPnP on your streamer in this order:
All Music
CD Collection
Devices
Internet Radio
You can ignore the Internet Radio input from now on.
Just found this thread. Why should radio be more stable through server (NS01) rather than streamer (NDS)? Have tried this but very slow finding stations with former. Advantage is being able to browse music whilst listening.
I don't know the buffer size on the Squeezebox Touch, but today I rebooted the Mac Mini running the LMS server app for my SBT, and Radio Paradise 320 didn't miss a beat! And the Mini takes 2-5 minutes to come fully up with its modest conventional hard drive. (Refreshing my iPeng session did cause a one second drop out, though.)
Surprising, to me.
Nick
