n-Stream new version update
Posted by: Mohamed Amin on 14 August 2013
Any one having problems with today's release of n-Stream update , Installed fine on iPhone and iPad, but the Uniti2 although being seen on the n-stream dose not respond to any command from the n-stream on both phone and iPad. I unplugged the uniti2 and rediscovered it with the n-stream  it can read my albums but uniti2 doesn't respond to n-stream
unity is functioning normally via its own remote control
Posted on: 14 August 2013 by sjbabbey
Do you need to have updated to the new 3.21 firmware for the new version of n-stream to work properly?
Posted on: 14 August 2013 by ChrisH
Yes that's right sj.
In the App Store it confirms that the new app version is supporting firmware upgrade 3.21 ( released yesterday Mohammed.
Posted on: 14 August 2013 by AndyL
How do I check which firmware version I am currently running on my SuperUniti?    Thanks!
Andy, you can see it in nStream under Setup/About/streamer version. Hope this helps.
Thanks Chris will check when I'm home
Can't see a 3.21 firmware download file available for SU on  http://www.naimaudio.com/updates - is it somewhere else?
Thanks again
Posted on: 14 August 2013 by Bart
Thanks again
http://www.naimaudio.com/news/...update-now-available
This will get you there.
If you go to www.naimaudio.com, you will see it under 'News': Multiroom Update Now Available. The link will take you to the Updaters. The only other noticeable change with this firmware update is Seek to Time function, though I'm sure there are some enhancements beneath the hood....
Ha , you were too quick for me Bart!
thanks both; odd it's not on the update downloads page though
I'm sure it will be Andy, as soon as the Naim team are back off shutdown next week.
Posted on: 14 August 2013 by Mohamed Amin
Many thanks , I should have thought of that initially !! better go and do the firmware update
