Uniti 1 Firmware 3.21 alarm clock
Posted by: Stephan K on 15 August 2013
Hello together,
yesterday I have updated my Uniti 1 with the latest firmware (without any problem).
This morning I mentioned, that the alarm started, but the display does not blink and the volume was not ajusted to the value in the alarm settings.
Also, the alarm does not stopp after 30 minutes as I am used to from the last firmware.
Can anybody confirm this behavier?
Stephan
Posted on: 15 August 2013 by Nagoya
My display does blink and the volume setting works. Are you definitely sure that your alarm is misbehaving? Thanks!
Posted on: 16 August 2013 by Woj
It happened to me too! I also have Uniti 1 and this morning the alarm started but the display does not blink and the volume was not adjusted to the value in the alarm settings. I think the volume was at the level I left it last nigh (pretty loud).  Exactly same behavior. Shall we report that to NAIM somehow?
Posted on: 16 August 2013 by Nagoya
I have a SuperUniti, so maybe this is just on the Uniti 1. Anyway, tell Naim. Thanks!
Posted on: 16 August 2013 by osprey
Originally Posted by Woj:
It happened to me too! I also have Uniti 1 and this morning the alarm started but the display does not blink and the volume was not adjusted to the value in the alarm settings. I think the volume was at the level I left is last nigh (pretty loud).  Exactly same behavior. Shall we report that to NAIM somehow?
You could send an email to support@naimaudio.com describing the problem. The answer comes back usually quite quickly (Naim staff do read/follow this forum but apparently not extensively).
Thanks. I just sent an email to Naim support.
Posted on: 20 August 2013 by Stephan K
Since Monday the alarm clock worked as expected.
The only thing I have done is reprogramming the alarm.
Very strange.
Posted on: 21 August 2013 by Woj
Mine is working too after re-programming.
