error message on HDX-SSD
Posted by: Saavedra on 07 February 2011
I've just bought and installed the hdx-ssd and I'm having some problems. First of all I often get the following error message:
Program memory is very low. You must select one task to close or increase the amount of program memory, if available.
Convert some storage memory to Program memory (You can use the system control panel to adjust memory later).
So exit this window I have to shut the machine down and then turn if off and back on on the switch.
Can anybody explain me why this happens and what to do about it.
Thank you
