Naim DAC and Sonos debate - blind testing
Posted by: lamby2244 on 07 February 2011
On another forum I have been having fun time in a thread about the benefits/value of putting a DAC in your system. The root of the discussion is that I can hear the difference the NDAC makes in my system but I am being bombarded with data about how blind tests show that there is no audible difference in most kit, particularly amps. Anyway I was wondering what you lot had to say and whether there were any examples of blind tests that showed a positive result for high-end kit?
The heart of it is that the chap is arguing that speakers are the key to your system potential, which is interesting as the move from Ruark CL20s to Neat Ultimatum MF5s was my most significant upgrade....
Anyway I am going to do my own blind test -
1. NDAC vs Sonos onboard DAC vs Benchmark through my 282/200/2xHicap setup
2. ZP120 vs Sonos/NDAC/282/200/2xhicap (this seems mad but hey I am going for it)
You might think I am mad but I now have something to prove - even if it is to myself.
Oh yes and the spice in the mix is that if the test is negative I sell my Naim kit......
Difference was rather negligible, to my ears...
Although, I wouldn´t sell my Naim kit. No way!
Elevated it to another level with a demo of NDAC, to the extent that a week after returning the demo unit I'd ordered one. The Sonos, as well as sounding great through the NDAC, is just so user friendly!
John
- Assuming that your brain plays a part in your experience of what you have, so far, considered the Naim sound, once you don't have the black boxes you don't have the sound anymore, anyway;
- Naim gear is beautiful; why settle for anonymous boxes when your brain uses that beauty, too, for configuring Naim sound?
- Naim gear is reliable. Whatever trick it plays, it will always work the same way on you. I've found that in the universe of cheating that the world of Audio is, Naim is a bit like Austria: a nice place that will always be where you look for it, the way you expect to find it.
M.
Sonos ZP90(digital Co-ax)/N-vi/NAP 200/Monitor Audio RS8's
against the N-vi disc player/NAP 200/Monitor Audio RS8's
What I can say is that as an interface the Sonos (with the CR200 remote or iPad app) it is a great system. Easy to set up and use.
However I (and my blind listening panel) were all surprised (and a little disappointed) that the sound of the Sonos was no where as good as the N-vi. The only way to describe the Sonos sound (when compared - it does sound OK on its own) is that there is a veil over the sound. You lose lots of detail and it just sounds flat and lifeless when compared to the N-vi.
Now given that the N-vi is a compromise as a CD source, then you can only begin to think of the difference between the Sonos and other higher end Naim kit. Maybe Sonos/NDAC may be different, but I would be surprised.
What it has done is give me great anticipation for the NDX. The Sonos has sold me on distributed audio, just that the quality of my CD is still better. If I could get the same sound with the Sonos convenience, then I would be very happy. Maybe the NDX will do this, but we will have to wait and see.
Andrew
I am with you. The Sonos/NDac/282/200/2x hicap/Neat Ultimatum MF5s is a good enough set up for me and to my ears the NDAC makes a huge difference - as you say almost removes the veil.
John
M.
- the fact of putting a Sonos system into a Naim DAC seems as good soundwise as putting a CDX2 into it or a HDX;
- therefore, using a Sonos instead of a "bare" HDX or Unitiserve through NDAC is really a choice of conveniency, ease to use, preference in the interface and quality of the multi-room device you choose to go with;
Am I right, or did I miss something?
Arnaud
You missed something. One person's opinion of a one shot trial in the context of his particular system with his very own ears. Your mileage may vary as they say.
Cal
Arnaud
Arnaud,
Your conclusions don't follow. First my Sonos ZP90 streams into the SuperNait's onboard DAC not the Naim DAC, different things!! Given my experience you might conclude that Sonos streamed into the SN's DAC can be as good sounding as a CDX2.2 but it needn't be necessarily so. This would depend a) on the quality of the file being streamed and b) on the amplification in place, I would imagine. Same set up into a 282/250 or higher might produce different results, don't know.
Second, both the HDX and UnitiServe can stream upwards of 16/41, something Sonos cannot. It is limited to 16/48 max. The higer res the source file the better the final SQ, especially through the external nDAC. So while Sonos can deliver very good results, it is not on par with the HDX or UnitiServe.
Whether Sonos can produce the same results as a CDX2.2. into the Naim DAC is something that I have not tested and cannot comment on. What I can say is that there were contributions on the previous forum by members who streamed WAV files off a NAS via Sonos into a Naim DAC/555PS/552/500 system and compared it to the results of their CD555/555PS and while the CD555 came out on top the results where apparently quite acceptable.
You can draw your own conclusions from this but needless to say you are best advised to do your own comparisson tests. People hear differently and what might work for one may not sound satisfactory to others at all.
Personally, on second thoughts I doubt I will change to the NDX, seem like an awful lot of money to spend for a streamer and Internet radio. Unless it beats the Naim DAC, I don't see the point really. Too early to tell.
Best
tp
I feel that all so many changes brought by streamed music make it difficult to follow and to settle on an opinion, at least for me.
That's why it's great to have feedbacks and to have A/B personnal auditions, I agree.
Arnaud
It's killer advantages in my view are
design & reliability - works flawlessly, very easy to set up - as said above "like Austria" or more traditionally does exactly what it says on the tin
integration with i-tunes - no faffing about to play apple lossless files on my network drive, this is critical for me - Naim please take note
control - i-pod/pad app is excellent and means I don't have to spend nearly £300 on a controller and it's no extra charge - Naim take note again
price - excellent value for money
one thing I have found - having the NAS attached directly to the ZP90 and powered from the tacima power strip plugged into the same double gang socket as my Graham's hydra has a significant negative effect on the sound quality of my system. This may be NAS dependent, but I've had no problems streaming wirelessly from another room, so I'd recommend anyone who finds Sonos SQ significantly inferior to CD and has only used a local wired connection, on the assumption wired is best, to try streaming from another room.
Only significant disadvantage is no hi-res capability, but I'll have had £300 of value out of the units by the time that becomes a aerious constraint.
Anyway toe-dipped, I got my second unit in my Xmas stocking and it's odds on I won't get through 2011 without adding a third.
Olly
Ipod 160g + Wadia 170 + nDac+ SN into Totem Model 1 Sig
and
MacMini + Sonos + nDac + SN into Totem Model 1 Sig
Absolutely no doubts, the Ipod/Wadia 170 sounds deeper and better soundstage. Lets not forget that Sonos ZP90 streams wireless.
Then I took out the nDac to try just with the SN dac. Both ways. Again, the winner is the Ipod/Wadia config but less clarity, fluidity and deepness. So, for me, my best setup for now is with an Ipod. Incredible. But I think that Sonos is very very convenient and I like when music is background or when I have to listen to very low volume when everyone sleeps in the house and I'm still up, rockin!!!
So lamby2244 what was the outcome of your test? Would be good to read about your experience here.
Or did you end up selling your Naim? ![]()
Thank you Yippedidou, that's interresting.
But wouldn't it be fair to make a comparison with the Sonos device being wired to the nDac?
Arnaud
ok sorry, I hadn't understood that.
sincerely
A
This is the thread I am looking for! Perfect!
Was wondering myself is it worth the extra bucks for the SU compared to a Sonos into a SN. Cant imagine
that a built in streamer would sound better lets say both DACs are the same. How come Some say the SU might be the better option SQ wise vs Sonos digital out into the SN Dac. If no big difference, might as well save the extra for more music stuff. Or if more fund allows, the nDAC. ![]()
Thank you
