nStream crashes on (server) playlist
Posted by: CharlieP on 05 September 2013
I would like to know how to troubleshoot this problem.
I view the playlists from my server in nStream on my iPad, expecting to play the music files in "shuffle." I hold my finger on the name of my desired playlist, thus opening the popup menu. I select "Play" and nStream "vanishes from the screen in a panic. There are some playlists which play normally, and some which always produce the panic crash. (Note: this is not a local playlist created in nStream - these were created on the server).
Upon restarting nStream, I return to the playlist and select it. nStream shows me the tracks in the playlist. I do note that iTunes reports 200 songs in the list, and nStream reports 191 songs. Hmmm... With this many songs, I have not yet attempted a tedious comparison to find which songs are missing.
I get this behavior often using Asset UPnP server (running in Crossover WinXP emulation) an less often using Playback as server.
My system is:
- late 2012 Mac Mini OSX 10.8, Playback or Asset (in Crossover)
- UnitiQute 24/192, firmware 3.21.000
- wired ethernet thru network switch
- iPad2 64GB, IOS 6.1.3 (10B329)
- nStream 3.4.7079
I see that a "LatestCrash-nStream.plist" file was created, which is forwarded to Apple (I think). I assume this is a vulnerability in nStream - is there information I could provide to help the Naim development team?
More importantly, how do I work around this? I noted some songs in the list had missing files, but when I delete them from the playlist, that did not fix the problem. Only three apps are running on iPad. I have cleared the UPnP cash in nStream.
Enjoying my other playlists....
