FLAC and MP3 encoding using n-Serve for Mac and 1.7a
Posted by: dschoem on 29 September 2013
Apologies if this has already been covered elsewhere, but I've scoured the forum and don't seem to have found anything covering this specifically, while there is no clear reference in the 1.7 updated manual either. I am running a UnitiServe SSD in conjunction with a Synology 213+ NAS, on which the Music Store contains about 1 800 CDs in WAV format. Having now updated to 1.7a, it seems that my current library of WAV files can be encoded to FLAC, while new rips can be encoded from the outset in either FLAC or WAV. There also appears to be an option to simultaneously encode to a parallel MP3 library at a selectable bit rate. However, it seems that encoding existing WAV files in the music store to FLAC replaces the WAV files with the new FLAC file. Is there any way the new FLAC files can be stored in another location while retaining the original FLAC file? Also, if MP3 parallel encoding is enabled, is this only true of new rips, or can a parallel library be created from existing WAV files, without compromising the original WAV files?
