usb
Posted by: rupert on 01 October 2013
hi if i use my usb how do i disable it after use its light wont go out regards,
You're in the right Forum, obviously.![]()
When you unplug your memory stick from the PC, the stick flashes even then? Or what?
The memory stick is flashing in the superuniti not in PC the PC tells you when to remove the uniti does not regards
If you're done using it, then just unplug it.
I'm not 100% sure, but my guess is that as long as it's plugged in, it will keep flashing.
Thanks for adivise better I phone naim if it works like a PC it can damage su at least PC tells me when it's safe to do so,
USB is designed to be plug and play. You can add and remove at will. The only possible damage that you can do to a USB drive by unplugging it is loss or data if a write operation is being performed. But you are not doing this so don't worry.
Thanks bannahead so it's different to a PC regards
Have you tried ejecting or "Safely removing it"?
