Nd5xs advanced settings
Posted by: Scooot on 01 October 2013
Hi,
Is the recommendation to leave well alone or can adjusting the settings improve things.my new nd5xs only came with a quick user guide and when I try and look on the naim website manual it keeps crashing at page 4.
Scott
Posted on: 01 October 2013 by BENEDICT
Hi,
I got mine 14 months ago with the same quick user guide but I managed to find on the web a reference manual for network audio players
It was then quite easy to set up the nd5xs
If you send me your email   i could scan and send you a copy
Best regards
Posted on: 01 October 2013 by Scooot
Hi Benedict,
Thanks for the kind offer.since my post I have managed to get a full online user manual so I will download and print the sections I need.thanks again
Scott
