Soft PVC dust cover for Unitiserve?
Posted by: Dozey on 02 October 2013
Hi All,
Decided I would like a cover to stop the machine getting dusty. Anyone know of a source?
Thanks.
Posted on: 02 October 2013 by Manu
Weekly cleaning?
Joke apart, it is not a good idea to cover the unitiserve
It can become pretty hot, covering it will keep the heat in and it may become too much.....
Posted on: 02 October 2013 by Dungassin
Isn't the case of Naim equipment part of the heatsink?  If so, a PVC cover is a bad idea.  Just dust it.
Posted on: 02 October 2013 by Bart
It gets WAY too warm to cover, unless you are shutting it down daily.
Posted on: 03 October 2013 by Dozey
Ah - good point about the heat, hadn't thought of that. Will have to rig up a parasol!
Posted on: 04 October 2013 by Jon Myles
Or a fan, perhaps.
With the added benefit that it will blow away any dust.
Posted on: 04 October 2013 by Jasonf
Dozey,
where do you keep your u-Serve, is it on the HiFi rack next to the other boxes? If so it is worth placing it away from the black boxes if you can.
Jason.
