N-stream not showing internet stations
Posted by: Stephen John on 11 October 2013
N-stream via my iPad is not showing internet stations although preset stations are Visible.Any ideas? Also, stations seems to be acquired more slowly than normal, and BBC R4 does not connect at all, although it was okay a couple of days ago. Feedback on these issues would be appreciated. Thank you.
Same here - no Naim choice etc., just the two presets I have set so far. Annoying. Using an IPOD touch.
Same here - station list empty. I've emailed Naim support.
Can see my presets only, but it changes between them v slowly and some eg Radio Paradise won't play.
Shame as until now it has been perfect.
Looks like an iRadio issue maybe -- the website is slow too. I think it's a network issue at the source, not some nStream issue with the app on the iDevice.
EDIT -- The website is now down, showing the same error message as seen last week (2 weeks ago?) when it was down.
Had a reply from support - do a factory reset with internet unplugged then plug router/modem back in.
Lost my presets but internet radio is back and working as it should.
Just saw this thread......
Like Osprey, my iRadio signal came back, but has now gone again and all the stations with it.
See here....
https://forums.naimaudio.com/to...ue#30569816353452692
I have no desire to reset the unit unless I know I absolutely have to.
D.
Clearly a few of us are having issues. I'm in contact with naim support about it.
Reply from Naim support is that they think it's something Virgin (my internet provider) are doing that causes vtuner to disappear. They are making enquiries.
Well, I'm based in Dublin using UPC and I had it back for about 30 minutes. Went again less than 5 minutes ago.
Nothing to do with Virgin, I presume?
D.
Had this issue last night, N-stream just shut down (twice) when I tried to get the station list to display & then just a blank page with only my presets visible...![]()
What is going on here? (In the broader web space, that is.) It's 2013 for heaven's sake!
D.
