What streamer/network to warm up my naim system
Posted by: prolle on 19 October 2013
Hi guys
Hi have a naim dac and Nait xs bit no source (apart from USB in the dac). So, I am looking for a dacless unit that will play internet radio and music from my home network. I would like something that would also warm up the sound and remove some of the harshness.
Any recommendations?
Posted on: 19 October 2013 by HTM_1968
I ran the nDAC with an ND5XS for a while. It was very, very nice, but there is a lot of redundancy (2 dacs etc). We traded both in against the NDS. I am sure that there are cheaper alternatives, and perhaps trading the nDAC in against a streamer might be a plan, or even trade in the Nait XS and nDAC against a SuperUniti. Demos are really called for, and preferably fairly lenghty home demos too!
Posted on: 19 October 2013 by Scooot
Hi,
I am also using a nd5xs into naim dac and I am loving this combo.
I have ran the nd5xs using the on board dac but after a lot of listening I can't let go of the dac.it definitely improves the nd5xs.as. Htm 1968 has quite rightly said you must do the home dem.
A possible solution at a reasonable cost is a used unitiqute 1.
Good luck,scott
Posted on: 19 October 2013 by Iver van de Zand
Hey Prolle,
There are plenty of options for you depending a bit on quality and the budget you want to spent. If you look for a second hand SqueezeBox Touch, you have a quick start with good sound quality for a small budget. A very interesting alternative might be to buy a Apple MacMini (search this forum and you will see all the positive feedbacks and tweaks) which - apart from music - brings you an extra computer and video player. Personally I'd search for a second hand UnitiQute and use that as streamer for your music and radio.
Iver
Posted on: 19 October 2013 by prolle
Thanks guys, I've been thinking of unitiqute but can't find them second hand in Ireland! As regards a nd5, I hate idea of dac redundancy. Doing my own research in the meantime, I've come across the Olive One! Looks great, anybody have any experience? Thanks
Hmmm, the NAD M50 looks nice!!
Posted on: 19 October 2013 by Kalius666
Look for a simaudio moon 180 MiND. It's a streamer 24/192 without a dac inside.
Posted on: 19 October 2013 by Rich27
+1 to this recommendation, the Moon is excellent and not too expensive either.
