ND5 XS Nac 202 - System Automation - control of NAC 202 volume by IR
Posted by: nickpeacock on 22 October 2013
Evening All,
I'm really enjoying my ND5 XS.
I have an issue with system automation in that I can't control the NAC 202 volume by IR using the ND5 XS remote.
Steps so far: connected 3.5mm jack from ND5 XS remote out to phono remote in on NAC 202; reset system automation factory settings for good measure; in system automation enabled Preamp-CD; set streamer audio to Preamp-CD.
I can successfully control the NAC 202 volume using n-stream/iPhone.
But I can't control the NAC 202 volume using the ND5 XS remote - anyone got any idea why not?
All help, as ever, gratefully received...
Posted on: 23 October 2013 by james n
Is it supposed to do this. I thought volume control via system automation was only through the app.
James
Posted on: 23 October 2013 by Scooot
Hi,
My nd5xs remote operates my 202 volume.if I remember correctly you have to turn off the nd5 wait a little.when you see the nd5xs logo on the display you need to press some buttons on the nd5 remote.this should sort it.sorry I can't remember wich buttons.at the time I did a forum search and found a topics related to this issue.
I am a work at the moment but if any one else has not chipped in by the time I get home i will try and help further.
Scott
Hi,
Just another point.what you have done so far is correct but this only sorts the n-stream side of it out.
Scott
Posted on: 23 October 2013 by nickpeacock
Thanks, Scott. Is it aux, i, 5 (same as for hard re-set of remote)?
Hi Nick,
I am not sure of the exact buttons to be pressed but you are on the right track.do a google search for either "naim remote ir codes" or "nd5xs/202 automation.
Alough the later is mainly about getting the n-stream app to control volume the information is there.you may just need to scout about a bit.
One things for sure it can be done,
Good luck,scott
Thanks, Scott - I've nailed it!
Turn off; turn on; aux, i, 2
Now the ND5 remote controls the 202 volume via IR.
Hurrah!
Hi Nick,
Nice one mate.happy days.
Scott
