No Sleeve Artwork on nstream
Posted by: musica on 02 November 2013
Hi
Since the latest ios update I am having problems with nstream On my ipad.
The first problem is that if I install an update to nstream or reset any network settings on the ipad nstream crashes when I open it. The only way to overcome this is to delete nstream and then reinstall it. It will then open correctly.
The second problem is when I rip CDs I do not get any sleeve artwork. The Metadata is fine.
The sleeve artwork is also missing when I look in nserve. I am however able to get the artwork on nserve by using the online search facility. This artwork will then appear on nstream but only if it is in UPnP mode
The question is why is the artwork not appearing after ripping, and when I obtain the artwork online why does it only appear on nstream in UPnP mode.
i watched the ripping process on nserve ,where lookup and ripping performed ok.
Any help would be much appreciated.
Philip
Posted on: 02 November 2013 by hungryhalibut
Very bizarre. I'd contact Naim directly for advice. I've no idea.
