Do I need a NAS Drive instead of my FireWire affair?
Posted by: The Author on 06 November 2013
Hi All
I need a recommendation for a NAS Drive. Currently I’m using a Western Digital My Book Studio Two FireWire external hard drive connected to my iMac - ouch.
A few months back, I accidentally selected this drive to do a ‘SuperDuper’ back up to (SuperDuper is a cloning tool for Mac), and erased all my music fills, replacing them with a clown of my main hard drive - ouch.
Now, I’m going to have to sit by my computer and re-import three large boxes of CDs (so glad I didn’t sell them).
Now, as I want this to be the last time I do this, I figured the computer hard drive I’m currently using is probably not the best route as I need to have my computer on to play music.
I’ve heard Qnap are pretty good and was thinking of a TS-220 with a couple of 2TB Western Digital RED drives in. I’ve heard the WD RED drives are for server purposes and can run all day and they don’t get hot and they run quiet. Also, I doubt I will need more than 2TB space. Also, if I have 2 x 2TB drives mirrored I will also have the safety of a back up.
Finally, I am sure this won’t make any difference, but although all my amps are Naim (Olive series 250, 72 and hi-cap) my streamer is a Linn Magic.
Is the Qnap the way to go?
Oh yes, one more thing. On an Apple Mac, what software would you recommend for A. Ripping and B. Sorting. I have been using iTunes with Apple's AAC Lossless codec, but I've heard that FLAC is the way to to, which iTunes does not support. So, any recommendations for ripping software and software alternative to iTunes that can play back FLAC files on my Mac? I'm using Linn Kinsky for my Majik DS.
Any suggestions or feedback before I spend £495 with Ripcaster.co.uk would be greatly received.
Thanks all.
