Changing uPnP server on a qnap nas ( newbie alert again)
Posted by: Ingenius on 06 November 2013
Hi There
Just a short and maybe " daft " question:
My Qnap Nas came with Twonky media UPnP server already on it. Is this just softrare or hardware ( firmware) I read on this forum a lot of people having issues with Twonky. Can it be easily disabled and replaced with Asset UPnP which seems the prefered choice on this forum. ? I havent found any issues yet as i am still waiting for my Superuniti, but thought i would ask
thanks in advance
Keith
Posted on: 06 November 2013 by roo
Twonky is a built-in QPKG application which you can disable on your NAS. As far as I know Asset doesn't work on an ARM based QNAP NAS. Which QNAP model do you have?
I've installed minimserver on my TS-119P II and it works much better than Twonky. The installation isn't that hard if you follow the instructions on the minimserver web site but it isn't as simple as just installing a QPKG so depending on your level of computer skills it may not be for you.
Posted on: 06 November 2013 by Ingenius
Hi Roo,
thanks for your reply.. i believe the cpu to be a Marvell 6281. Thanks for the info on minimsever. i may look to that if twonky doest work out.
regards
Keith
Posted on: 06 November 2013 by sbilotta
+1 for Minimserver on QNAP.
It transcodes too !
Posted on: 06 November 2013 by intothevoid
Minimserver is ok if you really must run uPNP on your NAS, but Asset is better if you have a little old windows box lying around.
Installing Minimserver is really straightforward and it seems reliable, if a little slow to index. My main gripe is how nStream interacts with it, as the album art only shows at album level, not at artist/album like Asset does.
Not a biggy I know, but it helps identification and is more aesthetically pleasing.
Posted on: 06 November 2013 by Madrid
Asset on an old 2005 Dell pc works great for me.  IMO, much better than Synology´s UPnP.
Posted on: 07 November 2013 by J Saville
I have been playing around with Asset for Raspberry Pi, works a treat! There is a write up in the thread on the DBPoweramp forum on how to point it at a NAS drive.
I tried Minim but found the lack of WAV tag support disappointing.
