B&O Play V1 32
Posted by: NickSeattle on 07 November 2013
Just had a 32" black-beauty on a swing-arm installed in the Master Bedroom.  Not cheap, but definitely a cut above the Westinghouse it replaces.  The total package, and especially the assertive pursuit of the best possible implementation/installation by the certified installer, is delightful.
The display itself is really excellent, but that is only half of what is delivered.  Sound is really good (for a TV) and the UI, once configured, is the best I have seen.  I especially like the latest updated Beo4 remote -- so different from the cheap plastic remotes with so many buttons you cannot navigate in the dark.  But I am used to it, after 15 years of use with my 2500/8000 system.
A true luxury product that delivers much more than cachet, IMHO.
Nick
