yamaha dsp-e800 connections to supernait and napv175
Posted by: rael on 23 November 2013
I have just bought the yamaha dsp-e800 processor as a temporary measure whilst the av2 is due to go in for repair, long story and won't be back for sometime. So in the meantime, can someone advise the connections required to connect the Supernait, NapV175 to the yamaha processor for best effect.
I will obviously read the manual re connections, but just wanted to check how existing users are connecting this equipment as I don,t want to damage the SN, by getting it wrong.
Many Thanks
Posted on: 23 November 2013 by Richard Dane
You'll need an RCA lead.  Connect from the front pre-out on the Yamaha to the AV input of the Supernait.  Make sure Unity Gain is set to on.  For the NAPV175 you'll need two sets of RCA to DIN4 leads for centre and surround channels.
Posted on: 23 November 2013 by rael
Hi Richard
I thought I would check, so I will need to buy some rca to din4 leads ...
many thanks again, for your quick response, much appreciated.
