Power Line on Unitiserve?
Posted by: Russ on 26 November 2013
I know I have seen something on whether there is any improvement effected with this combo--somewhere, but I am simply unable to find where I may have seen it. Any info?
Thanks,
Russ
The mains lead supplied with the UnitiServe incorporates a filter to stop noise from the supplied SMPS entering the mains. You'd therefore be unwise to replace that lead with a Powerline. What you can do, which I wholeheartedly recommend, is to buy a bespoke linear power supply for it. Look in my profile and you'll see details.
You could use a Powerline with this power supply, which I have not had the opportunity to try, though I'd be very interested in the results should anyone else have given it a go.
I have. Slightly better. If you already have a PL "left over" its recommended, otherwise not (price/performance ratio).
Im sure a lot of people here can explain why that is impossible (improvement) but Im also sure they haven't tried for them selves.
Maybe Im just getting cynic...
//Jonas
Jonas, i would not think you to be cynical, just that you have a feeling of 'déjà-vu' I suspect !
Thanks very much, all. Halibut--your post reminds me that what you say pretty much was what I read before. Good to know.
Best regards,
Russ
