Naim Uniti System Error,Connect to USB for charge portable battery
Posted by: thx1139 on 09 December 2013
I connected a portable battery (Targus 4800mA) to front USB port of Uniti (the first model) for charge about couple hours
and power off/on the system maintained battery.
At that time, automatically turned off the LCD of Uniti .
and then automatically reboot the system repeatedly.
After all, I must have A/S ... , cause some inside power lines are dead.
Posted on: 09 December 2013 by garyi
You connected a battery to a usb input of a uniti?
Eh?
Posted on: 09 December 2013 by Richard Dane
The manual states that the USB port on the original Uniti is only for USB sticks.  I'd imagine that connecting a laptop battery would probably cause some damage, which seems to be the case here.  Get it to your dealer so they can assess this and repair.
