Playing FLAC files on a MAC
Posted by: Sundance on 22 December 2013
Am I missing something here? How do I easily play these hi def files? After downloading from HDTracks couldn't work out how to play them til I discovered XLD, but it's not exactly user friendly and I haven't worked out how to queue tracks.
Have I got to live with using different software iTunes, Spotify, Sonos and XLD???? 8-(
Soon I'm going to start using qobuz and so on....
Posted on: 22 December 2013 by Aleg
Sunny
Here ( http://www.audiokarma.org/forums/showpost.php?p=6383396&postcount=3    is an overview of most Mac software capable of playing flac.
most popular appear to be Audirvana+ and Decibel
cheers
Aleg
Posted on: 22 December 2013 by Tog
Audivana + works well with flac
Tog
Posted on: 22 December 2013 by skipper44
VLC is an unfussy little gem -  gratis and good to have onboard.
jRiver Media Centre does the job eminently - pay after an extendible trial period  of a month or two.
You are about to enter an infinitely flexible, customizable world and the notion of "one ring that rules them all" is about to go out the window, erm, down the fiery abyss.
You will likely settle down with one of the mentions in this thread. They all have their adv and disadv's and they're all getting better. The composition of your set-up will influence what suits you. It maybe best to stop looking when you find something that works for you.
Good idea to understand terms like "library", "transcoding", etc. if not already part of the personal streamer hifi lexicon.
Enjoy/groan if geek/not.
skipper
Posted on: 22 December 2013 by The Meerkat
Sundance...I am a Mac user and downloaded XLD on Friday. I converted one album (WAV to FLAC) just as a test, but I'm damned if I can work out how to actually play the converted files. Where is the player in  XLD?.
Today however, I downloaded 'Jriver Media Center 19' for Mac, and it's fantastic! Plays all my Hi Res files perfectly. There's also an option to tag your stuff.
Posted on: 22 December 2013 by garyi
I know I sound like a stuck record but plex is your friend here is a quick screen grab of mine:
It will 'scrape' your music, that is to say it will check your meta data and return a wealth of information relating to the artist and the album, I have not found the artist pictures for instance, it does that. There is plenty of methods to access and play that music, and just about every music format is supported including FLAC.
Check it out.
Gary - don't apologise - Plex is a true gem.
Not sure if it is bit perfect though yet.
Tog
Posted on: 26 December 2013 by Jude2012
Tog
Hi Tog,
I have been A+ with iTunes integrated mode with AIFF or ALAC files.  How do I play FLAC files, I haven't seen it clearly anywhere ? I may be missing the obvious.
Jude
Posted on: 26 December 2013 by Tog
Tog
Hi Tog,
Jude
This is where the Apple "walled garden" approach gets in the way - there is a workaround that is best described by A+ themselves...
"If your files that are not recognised natively by iTunes (e.g. FLAC, Cue Sheets, DSD, ) you can use the “Add Files to iTunes” command in the Audirvana Plus menu to create small proxy files that’ll be catalogued in iTunes and enable playing of all those files using the iPad/iPhone Remote app."
 Tog
Posted on: 27 December 2013 by Jude2012
Tog
Hi Tog,
Jude
 Tog
Thanks @Tog.  I will experiment with this.  Do you use this feature and find works well for you?
OP, I hope this not too much a diversion from your original query.
Jude
Posted on: 27 December 2013 by james n
Jude - Just use XLD to convert the FLAC files to AIFF and then use your normal player.
Thanks James, this is what I do and works extremely well.  I just thought that a short cut was available to save the conversion. It is good to hear that others consider this the 'norm'.
@ Meerket, XLD, AFAIK, does ripping, metadata, and file conversion comprehensively.  It does not do file management and playback, so you would need a software solution that does playback (I use iTunes and find it works extremely well for me)
J
