Uniti 2 switch off LOGO
Posted by: Rembrand on 25 December 2013
Does anyone have the option found? The next sentence is copied from the manual.
The Logo Off settings select the circumstances in which the front panel logo illumination will switch off.
I can´t found it!
Best regards
Posted on: 25 December 2013 by hungryhalibut
Press the spanner on the remote. Go down to 'front display' and you will find the logo options.
Posted on: 25 December 2013 by Rembrand
Sorry I start with 3.18 and now i´m on 3.22 and on now Firmware i have the option in the Frontpanel
menu. Do you have the option?
Posted on: 25 December 2013 by ChrisH
As HH says, press the spanner button on the remote control handset, then front display, then Logo Off, and you have the options  Logo Off if muted / if display off / always / never.
Take your pick!
I don't have the Option Logo off. I have only three options
1 off During Mute
2  auto off
3 clock when off
but no logo Option.
When you get to the front display screen, you have five options:
off during mute
auto off
clock when off
logo off
logo mute
Scroll down to the fourth option - the top of the screen will say 'front display 4/5'. This is because the logo off option is the fourth of the five options.
When you get to the logo off options, you will see the four choices.
Posted on: 26 December 2013 by surfer
I only have 3 options as well, the menu actually says 1/3!
Posted on: 26 December 2013 by hungryhalibut
Both Chris and I have Superunitis. I now wonder if the Uniti2 is different? I was assuming that the 3.22 firmware worked the same in all the Uniti series, but as they say, 'never assume'.
It's very strange how these 2 options have been omitted from our units.
Posted on: 26 December 2013 by Russt
My Uniti 2 running firmware 3.22 has only 3 options also. The same as Rembrand.
The manual states there should be 4 options with the 4th option being 'logo off'
So I'm confused!
Posted on: 26 December 2013 by Rembrand
Thank you for your answers. So now i´m shure that it is not a unique problem of my Uniti2. So i like
to have this option but if it is not available NAIM has to change it in the manual or fix it. That´s bad for me. The only reason why i bought the Uniti2 is that i will have a amplifire  where i can switch off the LOGO.
Yes your right about the latest manual release, that currently shows a 4 option menu, with logo off the 4th option!
I wonder how long it will last for left permantly on? Hopefully its Led
