Streaming to bedroom from HDX & NAS issues
Posted by: ray sheldon on 29 December 2013
All,
I'm quite useless at I.T related issues...
I have an HDX in the lounge with Netgear NAS. That all works fine.
I have a Pure Sensia in the bedroom, the wireless signal is ok as I can stream internet radio no problem, it shows a signal strength of 97% using the wifi booster situ between the 2 rooms. It even streams paradise radio at 320kbps so ive no issues with router/wifi booster.
When I select 'media player' on the Pure Sensia, it shows 'Mybooklive-twonky' which I think is the NAS in the lounge.
when I click on it, it opens all the the library, similar to what you see down the left hand side of IPad when using the nserve. However, if I say select 'playlists', it shows all the tracks within it, when you click on a specific track, it shows the name of that track on a different part of the display on the Sensia, followed by 'unknown' and then continuously changes to other tracks within the playlist with no sound.
its not a fault with the unit, my other pure radio does exactly the same thing.
have I got to change some settings in the HDX or NAS or both?
Thanks,
