superuniti dab retune
Posted by: Patrick37 on 08 January 2014
hi. having trouble with dab on my superuniti before i retuned  i had a total of 50 stations, and after the retune  it said i still had 50 channels stored.  pressed the ok button after this and it now states there is only 22. lost all the BBC channels and more ..  did a retune this morning and nothing has changed.  checked the 12 element aerial and it's ok
Posted on: 17 March 2014 by FrankB
Hi Patrick - I had the same issue here (only 18 of 38 channels in the channels list).
It looks like a firmware bug.
I could get the right channels list, and I can tune all channels following this workaround:
1. disconnect the antenna cable
2. retune - you will get exactly 0 channels - surprise ;-)
3. re-connect the antenna
4. retune - you will get all of your channels back
Best regards,
Frank
Posted on: 18 March 2014 by Patrick37
hi frank
thanks for the info does naim no about this? if so i hope it will up dated in next firmware
take care
patrick
Posted on: 18 March 2014 by FrankB
Hi Patrick - I think Naim does not jet know the problem (for a long time your post was not answered) - how to address the bug?
Is the workaround also working on your Superuniti?
yes! thanks i saw phil harris last week and he no idea about it will sent this post
Great - than hopefully it will be fixed soon.
Posted on: 22 March 2014 by Decnaim
Hi Frank,
        I have just completed retuning my UnitiQute2 as advised in your methodology. 100% success, my long lost DAB stations have returned.
Sincere Thanks,
Decnaim
Posted on: 25 March 2014 by Patrick37
Hi Patrick,
It was raised to our software guys and as soon as I have any reply then I’ll let you know…
Phil
