New DVD Writer Wrong Connections
Posted by: Mr Paws on 10 January 2014
Hi to all,
I wasn't too sure which forum this should go in so apologies if I've got It wrong.
I've just opened my old eMachines PC and removed a failing drive to fit a new DVD Drive only to find the connecting plug/s are different.
On the old drive there were two connecting cables, one long thin multi plug and a shorter four pin plug but the new one has been supplied with just one thin cable and it doesn't fit any of the other possible plugs or on the motherboard.
My PC is seven years old now running Windows XP. I'm sure there's a solution like some sort of conversion cable but I can't find any joy on the Web.
Can anyone point me In the right direction please ?
Thanks in advance..
