NDS floating sub chassis noise
Posted by: Audiofool on 15 January 2014
While there was no music playing, in a silent room, I bumped into my audio cabinet ever so lightly and heard the NDS sub chassis make a light metal tapping sound. Similar but not exactly like knocking on the outside of the NDS case with your knuckle. I was able to recreate this sound by moving the NDS on it's shelf with a short quick move of the NDS or walking right in front of my HiFi rack when the room is silent. My listening room is on a suspended wood floor (2nd floor room), combine that with a 200 pound person walking right next to the HiFi and there is some floor flex and soft mechanical noise coming from NDS. I assume this noise is the NDS sub chassis moving on it’s springs and hitting the NDS outer case? Is this normal? It kinda freaks me out to hear something clanging around inside the NDS like a loose part in a $11,000 USD piece of HiFi gear. Does your NDS make a mechanical noise when you bump it or move it in a quick jerking manner? Is this normal for units with a floating sub chassis?
I think this is normal. I could certainly feel the sub chassis bouncing around when I remove NDS from the Fraim to clean the glass shelves.
The more interesting question - how much bounce around before there is damage... - maybe someone from Naim can answer this question....
+ 1
Might be worth reading the manual ![]()
Moving the unit with the locking bolts out needs to be done with care.
Moving it in a quick, jerky manner whilst unlocked is a tad daft...
As above. The internals are designed to move around and the odd clonk can ensue. Same for the 552. I have initiated some soft vertical clonks when setting up but I wouldn't subject it to a sideways jerk or sharp vertical movement, just to see what happens. I expect they are bolted together strongly enough and suspended generously enough to take a fair bit of movement, but why would I push it deliberately? It can't be any worse than lifting or walking (on a bouncy floor) past a suspended TT.
Yes I read the NDS manual BEFORE it came out of the box. Once the transport screws were removed the NDS has never been on anything other than a flat solid surface right side up.
The side to side jerking was me just pivoting the NDS as it sat on a shelf to trouble shoot the sound. I fear my initial description of what I did was far more violent then what actually occurred.
Bottom line it's not possible for me to walk past the front of my HiFi rack without the NDS making an internal tapping sound. OK maybe I can walk past the front of the HiFi without the NDS sound IF I walk like a stealthy audio ninja. But that ninja stuff is much harder than it looks. ![]()
Understood. It's just that I can't walk past the NDS without it making a soft metallic tapping sound. Is it possible that the NDS sub chassis has come off it's springs or has been unseated from it's normal correct position and that's why it makes this mechanical nose when presented with the slightest of vibrations? Seems to me there would be more room for the sub chassis to move inside the NDS without bumping into something and making a noise? I've had turntables on this very same cabinet and I can walk past the turntable without any audible effect in the record playback. I have an email into naim on this NDS rattle question. I will update all when I have a response. Thanks to all for the input.
Signed,
A Tad Daft
Check with spirit level that your NDS is dead flat?
Bobby
Thanks to all for the ideas and feedback. I'll update when I hear back from Naim support.
It could be me - but don't you think you are being a little over sensitive?
You might need to get out more!
Just a thought.
Tog
Tog
Tog in first 17 days of this year you have posted on this forum on 13 of those days for a total of 61 posts... and I'm the one that needs to get out more?!
I suspect that post come quite close to proving his point? ![]()
Tog's post is like the pot calling the kettle black.
Tog
He who lives by the sword, dies by the sword.
Well researched and well said.
Togs comment was un-called for.
"Just a thought" doesn't mitigate the comment.
I was suggesting a degree of of hypersensitivity - clearly not the case
Tog
Just a thought.
Tog
+1 . I don't think it's normal for it to make those noises just because someone's walking around on a wooden floor. I suspect there's something wrong with the tolerances.
