It's about time for another in the series of Howard's iMac questions.
Any idea why when playing YouTube videos the sound comes out of my iMac speakers, but iTunes sound goes via usb/dac?
This is a recent development, usually it's either all USB or all iMac speakers, I have looked around at various settings but can't see why this should happen.
Any help will be appreciated.
Howard.
Posted on: 18 January 2014 by tonym
Hi Howard. Go into the Midi settings window, show audio window and check that your USB DAC's selected for sound output. There should be a small loudspeaker icon next to it. If the icon's next to "built-in output" then click on the little gearwheel at the bottom, highlight the DAC & select for sound output.
Posted on: 18 January 2014 by BigH47
I see it, but for some reason it won't allow any changes, it seems to have both selected for sound output, ie local and USB. I disconnected the USB and the Terradac now does both duties . Lets see if it stays so,
Thanks Tony
