AV2's stock accessories and cable for unity gain input.
Posted by: Massimo Bertola on 23 January 2014
Hello,
I might be buying an AV2 because it seems a good bargain. I had one a few years ago, and I still might be enjoying good DVD sound in my stereo system.
The unit comes with an apparently classic grey, 5-pin, 180° interconnect, but I seem to remember that it was an 'inverted' one to use it into the Unity Gain mode of preamps and integrates, going from analogue input 3 of the AV2 into av input of the preamp/integrated.
The seller is not sure, so I ask someone here: did the AV came with this 'inverted' IC as stock cable?
Max
Posted on: 23 January 2014 by Adam Meredith
https://forums.naimaudio.com/to...-with-naim-equipment
Posted on: 23 January 2014 by Massimo Bertola
Thanks. For some reasons, I tend not to use the search function (mainly because I stumble into old posts of mine and feel silly re-reading them).
M
Posted on: 24 January 2014 by rackkit
Dave at Flashback cables can make up the missing reversed lead if the original is missing. If you need a longer run, he'll also fit the resistors that they need too. A quick google will soon find his site. Very fair prices too.
Posted on: 25 January 2014 by Massimo Bertola
Thanks, I know FBS and I have had cables made by him, including a long one with resistors for my n-Sub..
Always a good resource for missing cables!
Max
Posted on: 03 February 2014 by Manu
The Naim inverted Din5 cable has the yellow ring (instead of the green standard one)
Posted on: 04 February 2014 by Massimo Bertola
So, my AV2 has arrived and, as I feared, it comes with a standard, green-ringed interconnect and not the 'reversed' one.
Since my Nait5i has RCA sockets for AV input, am I correct in assuming I'll have to have a DIN to RCA cable, with reversed pin connections at the DIN side, made?
Sorry for the redundant question but I just want to be sure. My first AV2 came with the proper cable and my 202 had DIN AV socket.
Thanks,
Max
Posted on: 06 February 2014 by rackkit
That sounds about right if it's RCA AV inputs on the Nait Max.
