Are there any decent carpet cleaning machines out there?
Posted by: Tony Lockhart on 25 January 2014
I've just tried a borrowed Vax upright machine, and it's a noisy horrible piece of kit. I think it has made the carpet wet, foamy in some areas, and when it eventually dries I might be able to see if it cleaned the carpet.
In the machine's defence, the owner is a real Mrs Mop, always cleaning, and uses the wrong cleaning fluid in the tank. The machine only cost about £90 around 7-10 years ago, so I might be expecting too much.
Any help gratefully received
Tony
Posted on: 25 January 2014 by Blueknowz
http://www.vax.co.uk/carpet-cl...t-cleaner-and-washer
This is the one we use Tony , as you said you need to use the recommened solutions to clean the carpet....Jim
Posted on: 25 January 2014 by Tony Lockhart
Thanks very much. On its way, Amazon Prime:
I couldn't believe that price, so thanks for the recommendation, Jim.
That's only slightly more than the base models, so fingers crossed that Amazon perform as they usually do for us.
Posted on: 25 January 2014 by trickydickie
We have a Bissell Powerwash pro, very similar to the Vax, but a friend who borrowed ours preferred it to a Vax they had previously borrowed.
We bought ours refurbished, direct from the manufacturer, google Bissell Refurbished, they are surprisingly inexpensive.
Richard
Tony
Apologies, didn't notice you had already ordered, if you don't like the look of the Vax I may have given you a plan B!
Richard
Thanks Richard
Posted on: 26 January 2014 by ewemon
I just borrow a VAX from  friend they are fine but don't expect absolute miracles.
Posted on: 26 January 2014 by Colin Lorenson
My wife does a good job on the carpets
Oh dear....
Posted on: 26 January 2014 by Tony Lockhart
Yep.
We know.
Posted on: 26 January 2014 by Arfur Oddsocks
Oh dear....
I'm sure she does, but what about cleaning them?
Posted on: 26 January 2014 by trickydickie
Did you choose the gift option when ordering?
I value my testicalia too highly
