How do I switch off FLAC decoding on the UnitiServe?
Posted by: Jan-Erik Nordoen on 18 February 2014
Currently, recoding is set to "Native" under DTC, but the U/S still decodes FLAC files (which I thought it wouldn't do with this setting).
I would like to pass the FLAC files to the Naim DAC and have the DAC decode them... just to see if I can detect any difference between decoding on the U/S and on the DAC.
Thanks,
Jan
Posted on: 18 February 2014 by Aleg
DAC doesn't decode flac, afaik.
only when fed from usb-stick.
So output over spdif can only be pcm
Posted on: 18 February 2014 by GraemeH
This might help?
https://forums.naimaudio.com/to...l-it-play-flac-files
Posted on: 18 February 2014 by DavidDever
Thanks,
Jan
The Naim DAC can only decode FLAC files when played (as a file) from a front-panel inserted, FAT-formatted thumbdrive.  The UnitiServe will always decode FLAC (or any other type of encoded file) to a PCM stream when played locally via the SPDIF output.
You could put the files onto similar thumbdrives (one on UnitiServe, one on DAC) if you wanted to perform a A-B comparison, but it is possible that you may have some issues as the sample rate / bit depth of the file increases, due to limitations in the USB bus speed on the DAC (or the thumbdrive flash memory controller itself).
Posted on: 18 February 2014 by Jan-Erik Nordoen
Thank you Dave, Graeme and Aleg.
Much appreciated.
Jan
Posted on: 18 February 2014 by Simon-in-Suffolk
Indeed, SPDIF uses raw sample data within the SPDIF frames. WAV and FLAC need to be reframed or decoded respectively to be sent over SPDIF.
Simon
Cheers Simon. All is now clear.
