New Vinyl with HD Download Code
Posted by: Roadie Simon on 26 February 2014
Hi all....I'm liking the thinking of this because I'm thinking of an NDX as a near future upgrade!
How does this work...can the code only be used once or a few times...is there a time limit to redeem code & where from?
Posted on: 26 February 2014 by mutterback
Depends entirely on the record label. Some are one time download code. but, the files all seem to be DRM free - at least I've never encountered protected downloads. Even with a one time code, you can copy/backup the file as many times as you like once you download it.
One issue I've had is trying to figure out what bit rate the digital downloads are.  For example, the new Beck album didn't specify, and I'm worried it will turn out to be 320 mp3. Again, varies, some  are very clear about this, others aren't.
I've only encountered a time limit once - I think it was with Paul Simon's Graceland reissue. I bought the album after the code had expired, which was pretty annoying.  Customer service also varies a lot by label. In this case, I wasn't able to contact anyone.
Posted on: 26 February 2014 by Roadie Simon
Thanks mutterback, that's a help.
I guess in that case I'll save the codes until I'm set up for streaming.
I wouldn't wait. Just download them all now to avoid any issues. They may have a de facto time limit - like the record label changing download services, etc.  All you need is a regular computer to download and save the files. As always, be sure to back up.
Thanks again...sounds like a plan! Will have to connect laptop directly to "tinterweb" rather than wireless.
