Converting UnitiServe WAV files to FLAC files using XLD
Posted by: The Meerkat on 26 February 2014
I no longer have my UnitiServe SSD, and am now in the process of converting all my ripped WAV files to FLAC, using XLD, to be streamed with my ND5 XS. I'm also re tagging a few FLAC files stored on my NAS. (I am a iMac user)
Please can anyone advise? In XLD Preferences, under 'Output Format', I have obviously ticked FLAC. But there is also a 'drop down option' for compression, listed as 'None', 'Normal', or 'High'. At the moment it is set to 'None'. Does anyone know what the correct compression setting should be? The reason that I ask, is that the re tagged FLAC files have come out slightly larger than the original FLACs. This not issue re storage, I was thinking of quality.
