Streaming flac quality Qobuz into Naim DAC USB port via iPhone
Posted by: Sloop John B on 09 March 2014
I'm streaming Qobuz flac through it's iPhone app into the USB port at the front of the nDAC.
Does anyone have knowledge, opinions or experience of this?
Are there limitations to this approach from a sonic viewpoint?
I'm presuming it's the same a connecting to play apple lossless files and therefor an asynchronous USB connection is not needed?
Yes, I've done it and it sounds very good. I haven't bothered to do any comparative testing, but I can say it's in another sonic league to Spotify.
Keith
Quboz isn't available in the US yet. Do you know what quality the stream is?
CD
I did a small unblinded unscientific test with a few JJ Cale and John Grant tracks last night.
I'm coming to the end of my Qobuz trial period and wanted to see if I'd keep it.
Perhaps unsurprisingly i found that the hierarchy remained.
- CD555
- SBT>Teddy rca-bnc Coax>nDAC+XPS2
- iDevice>lightening>nDAC+XPS2
I would have liked to be able to get QoBuz through the SBT as then a more valid comparison could be made of QoBuz's quality.
I think it will be Spotify for me as 2 young sloops are quite into it and with my system Qobuz is not clearly differentiating its flac quality. (clearly better than spotify but clearly inferior to locally streamed audio so would only be used to sample music which Spotify will do fine for)
SJB
if only there were a way to get 24/96 or 24/192 out of the iOS devices. I would use it permanently into my NDAC and ditch the HTPC/MF Link 192.
CD
Love it! G and another loss - less HQ medium is vinyl.
Pono? Though doesn't seem to have a digital output. Has USB but seems just for transferring files.
You can theoretically get hi res out of an idevice if you use it as a hard drive. I haven't tested that. In my experience, "browsing" with the NDAC isn't worth it.
A pity you didn't get Qobuz working on your SBT. I installed the app on my Touch and had it running for a couple of weeks but decided on staying with Spotify so I uninstalled it. SQ wise it was obviously better than Spotify Premium, i.e. 320kbps v. FLAC, but I felt Spotify's catalogue was more comprehensive and suits my tastes better. Did you try the Squeezebox forum for assistance?
Dave
Dave
Thee is a thread on it by the app programmer and there were other people reporting the same problem and I added my tuppence worth but the thread contained loads of themes and these seemed to take precedence. I also contacted Qobuz who replied promptly enough but obviously as SBT is unsupported suggested I go to the app writer or get Sonos.
Not a big issue really. it would be such a sea change to have such a catalogue available at a resolution where I could not tell the difference between local streaming and cloud streaming that I think I'm psychologically in a better place without this!
SJB
SJB
SBT USB output -> DAC-V1 asynchronous USB input works a treat as well. ![]()
Dave
SJB
I had that app Louis, but it would only stream in 320kbs for me through the SBT no matter what configuration I tried.
I have tried the Ciúnas USB / SPDIF converter which did indeed up the ante but then I started to fixate on what USB cable to use etc. For the moment I've decided to stick with the SBT coax out into the nDAC. It's safer for my sanity!
SJB
SJB
I was intrigued your SBT not playing Qobuz FLAC files so this afternoon I re-installed the plug-in (from the list of other 3rd. party plug-ins) and now have it working again. Probably off topic but interested to know what your issues with the setting-up were.
Dave
How do you do this? I would tether my iPad to my NDAC and use Jremote app.
thanks!
Patrick
SJB
SJB
I appreciate the help but I've done all the above.
"the "above" above is a hyperlink!
It's not an issue for me. I have more music than I can probably ever listen to!
SJB
