Can not update the ND5-XS firmware
Posted by: Raymy on 11 March 2014
Just purchased the ND5-XS recently and finally set up. Tried to update the firmwares downloaded from Naim. I was following the PDF file attached. Checked the Mac's system info and found the USB Serial Converter. When running the Naim Updater, it stuck at the second window - the 'Select serial port to use' is blank. Tried the switch on unit within 60 seconds also but nothing happens.
Did I miss out something?
