24bit vs. 16 bit
Posted by: Graham Clarke on 26 March 2014
Used my wife as a guinea pig for a blind listening test yesterday. Played Lorde's Royals track through nDAC/XPS-DR in both FLAC 16 and 24 bit forms, the former ripped by dB PowerAmp from CD. I told her she'd hear the same track twice but made no indications as to which was "better" and avoided any tell tales during playback.
Often in demos the "better" item is played second so this time I swapped the order and played 24 bit followed by 16 bit. Having already listened to them I preferred the 24 bit as the bass seemed a bit cleaner and better defined.
Wifey preferred the 16 bit version, claiming it sounded warmer. Interesting net result, as sometimes warmer=coloured, musically.
Which lead me to wonder, when a recording studio master for 24 bit and for CD do they adjust any of the levels, compression, processing etc between the two or are they processed identically?
If they're not processed identically then any attempt to compare 24 bit vs 16 is potentially even more prone to variability and error.
