Streaming from Mac mini
Posted by: Milija on 28 March 2014
I have Naim ND5XS on local network and Mac mini. I want to stream FLAC and Apple Lossless file from Mac HDD. How to do it?
Posted on: 28 March 2014 by LeeTom
Run. Upnp server on your Mac mini. One of the easier and more popular choices is Minimserver.
Posted on: 28 March 2014 by Milija
Thank you.
Posted on: 28 March 2014 by pcstockton
JRiver
Posted on: 28 March 2014 by Massimo Bertola
I humbly add that the Squeezeserver 7.3.3 is free, auto installs, is totally efficient and unobtrusive and makes all you have on the MacMini visible in UPnP.
I use just that to stream the few files I stream from this MacBookPro into my SqueezeBox connected to my 42.4/140 studio combo.
Max
SqueezeServer is now supporting upnp?
Posted on: 28 March 2014 by likesmusic
Has done for a long time. And JRiver can "see" a Touch as a zone. And do gapless with the Whitebear plugin.
I certainly know of Whitebear but i thought you needed Whitebear to make the SBT visible to upnp servers.  When I last played with the combo the SBT constantly showed up and went away without Whitebear.
When I called SB tech support they said the UPNP settings in the Server software were only for use with the new "UE" line.
Good to know though....
-patrick
Posted on: 29 March 2014 by Tog
Minimserver is a much simpler solution with excellent SQ
Tog
Posted on: 31 March 2014 by Milija
Thank you.
I am using Miniserver
A
Tog
Posted on: 01 April 2014 by ragman
Tog
The upnp server software has an influence to the SQ? You think so, or your experience?
