iPad and iPod cannot find device when using Naim Stream App .However UNITE is connected and I can control via small screen and handset.
Also I am fully functional on N Serve for my main listening room.via same iPad and iPod
Router and Wireless seem ok
I am n stream 3.1
Any ideas
Posted on: 01 April 2014 by Scooot
Hi,
Try turning your unite off.leave off for a short period then turn back on.
I have had this once with my nd5 and the above resolved the issue.
Scott
Posted on: 01 April 2014 by Dimac
Scott
Thanks, for the help , I am back up and running, looks like i did not leave the unity switched off for long enough
Hi Dimac,
No problem,glad your back up and running.turning off and back on after a short while usually sorts out the problem you encountered.
All the best scott
