UnitiQute2 dropping connection with Synology UPnP
Posted by: Professor Fink on 18 April 2014
Hello everyone... I'm new here!
I purchased a UnitiQute2 and some Tannoy DC6 SE speakers last weekend and I'm getting there with all my setting up!
Been reading this forum and the Synology Knowledge Base to try and get sorted.
I have one key problem. I think my Uniti is losing connection with my Synology DS214Play in some way. Quite randomly it will be playing and then stop. Momentarily it tells me its 'connecting' then it says 'Play Stopped' You can go straight back in and play see all the music files, but as you can imagine it really spoils the enjoyment!
On the Synology I've turned off anything like transcoding, HDD hibernation, security anything I can think of that may be interfering.
I'm playing ALAC files stored on the DS214, wired across a network using the n-stream App on an iPad Air. My ethernet is all wired and is connected via a Virgin Media Super Hub. I have no issues using internet radio or with streaming via an Airport Express or playing files via USB, its just the Synology.
Would any one please be able to give me any pointers to where to look next for a solution or have you encountered similar?
Any help appreciated. Thank you.
Simon
